B8136sx2196
- 19
- 3
- Corsicana Texas
I’ve gone thought through the TM’s. Replaced the MPU. voltage is +/- 2.7 vac. Wired around the connector at the actuator. ( this action fixed the voltage to the actuator). I’ve cleaned all grounds and all connectors/ bus. the lights on the backplane are correct according to The DCS baseline. I have to hit the fault toggle to get the speed controller dc power light to come on. The engine will crank and run for about 5 seconds then sputter and die. I found once it cranks if I put it in battle short it will stay running. I can turn off the battle short after 20 seconds and it will stay running. The cim will indicate battle short is off and it will run great.
If you crank it, engage the battle short, and then turn of off in less than 20 seconds it will die just like the Normal cranking procedure. I think I’m losing voltage during the first 20 seconds I guess. I just don’t know how to proceed from here.
