Rebuilding after 15 years of storage
PHOENIX-GER
889
Germany
I love my Volvo Estate - not more that big cargo volume like the old 9 series which pack a 1x2 m bed mattress but still big enough to sleep inside or pack a brushguard...
Fuelcosts 140 Euro for the 820 km Trip and 2,14 Euro / 1 Liter Diesel and a whole day lost.
I couldnt find as a privat a General cargo forwarder otherwise i had use them.
The most just work only with commercial companies here.
Nevertheless the seller is a commercial companie but doesnt want deal as such. He made this job as private person ;-)
So if we wanted that part we had to drive ourself.
Fortunately, the highways were clear and we were able to return home quickly.
I have still some big parts on my purchase list which should go with an importeur by container on sea. This of course arrives in the customs port like Hamburg 300 km or if I am lucky Bremerhaven 260 km. Still not that far away but it is usually the time it need to drive that trip not the fuelcosts what make it hard for me to manage.
PHOENIX-GER
889
Germany
Round pattern 205 with 32 spline long input? Will that work with the stock 208 adapter?
Until i dont got a No Go from the engineer for roadapproval with history classification is our solution the 6.2 remanucactored with an 4L80e build after 1997 and the NP205 and 2 new driveshafts as the NP205 have a fix yoke we want use. The adapter should be a new one with a speedsensor for the 4L80e.
The goal is to have the history classification with minor changes with more useful drivetrain for us but having the original always in stock to change on 100% stock configuration if our son will sell the truck when he got him ofter we left this world. So the TH400 will stay like the NP208 with adapter and driveshafts in store.
The most value is on classic cars in 100% stock configuration.
Keith_J
1,318
Schertz TX
Great plan! That is my eventual goal on my M1031. It has a rare NP205 with 90mm input bearing and long 32 spline female. What makes it odd is the figure 8 mating flange. I have the correct adapter, just trying to find a good transmission.
PHOENIX-GER
889
Germany
Keith_J you have some transmission companies in the US that use the 4L80e in all variations with appropriate equipment on the application focus. Here in Germany, that's a bit more cumbersome but also possible. It will only be expensive if there is no core or overhaulable transmission. If one must buy thus a complete transmission again like us. . We have prices from 4000-6000 euros including controller for a remanuctored 4x4 4L80e in Heavy duty configuration with towing focus.
Another thought of mine was to use a TH700R4 transmission. I have already overhauled one myself from a van like the TH400 from our M1008.
But the TH700R4 transmissions are weaker. There are now remanuctoring kits for more load but whether they hold what a 4L80e promises I can not assess.
Transmission and Transfercase will be start after we have finally our engine back.
Actually last weekend the cargobox should be primed and next saturday it should be mounted on the truck again. Unfortunately, this did not work out - due to other duties. Once the cargobox is on we can disassemble the Sierra so that the frame can be sandblasted. A transport is more relaxed in stable dry weather.
PHOENIX-GER
889
Germany
Off frame restoration with simulated Desert Tan field painting?
😇 no its just primer and as the box cover the back from the cab are these surfaces just painted carc green 383 as you will not come between this area by mounted box. I know that some others also paint the box off the frame. We prefer on the frame as mounting will be not an easy job without lifting tools. I dont want damage the painting just by mounting.
PHOENIX-GER
889
Germany
The inner fenders were still provided with "Steinschlagschutz" from Mipa and the box is now ready to go back on the chassis.
Our choice was the first time Mipa
Mipa Underbodyprotection - Steinschlagschutz
easy to applicate with air gun and low pressure (2,5 bar/36psi) but also avialable as rattle can
can be also painted over
The finish in underbodyprotection and Cavety Sealing will be done with products from Permafilm
It is also the first choice for us in that product.
Permafilm Underbodyprotection
Unfortunately, my son was not able to install the electrics last week as planned. For this reason, I am now continuing with the electrical system.
The whole thing is much more convenient when the Cargobox is not yet mounted.
Start at the front... just check if all is on place before take all in the cable cover, the same for dashboard and rear.
My son had all prepare well after checking all cables
Only one cable was detected as "bad" => it was hide in the cable cover
repair was not von us - so it must be a repair during army service.
Even if it should have been a field repair ... something like that is dangerous. We can be glad that this has held until today without torching the truck
PHOENIX-GER
889
Germany
Steinschlagshutz? I love the German language, literally stone impact protection, all in one word.
Just like gloves are hand shoes in German.
Yes we have a lot of funny words, and i always try not to translate by the meaning of the word.
Steinschlagschutz = Stone beat protection rofl
impact = Wirkung, Auswirkung, Aufprall
PHOENIX-GER
889
Germany
Still a lot of progress in prepare painting.
The most is done and the final painting should be done on the 1st october if we can finish all preparejobs.
Thanks Rutjes :beer:we have now also a second skinplate for the tank on the right side. Needing just a little bit customizing
already primed now
all the "small" parts in and outside are in work now
painting is really timeconsuming... specially of different colors, just now primer and black - green is waiting in the queue
we found finally also the old cabs as you remember the surface of the new warn cabs should not be destroyed just for painting
PHOENIX-GER
889
Germany
First try with matt clear varnish
works great
we used Black 383 and matt clear varnish from Militaerlacke.de
the skidplates are now ready and fixed
and the interieur is now in the upholstery for leather covering of bench with improved padding (harder on the edges), sunvisors, doorpanels and dashpad.
We used leather middel red from mercedes as it fitted 99% in Color
Leather middelred
it is a lot of work just now in prepare the painting.
the best result shown up if you do the whole job with wet sanding. I start usually with 400er, 600er and final with 1000er.
Saturday will be the great showdown with painting.
I hope all will work without problems
flyfishtrailer
1,019
Cool, CA
Looking forward to the finished truck. You have done an outstanding job taking this truck back to as stock as you can. Perfect!!
PHOENIX-GER
889
Germany
@flyfishtrailer cant wait to have him back on the road.
We are fixing just now with enginebuilder the rebuild of the old 6.2 engine with all recommedated improvements to prevent again an enginedamage of heat.
Still not a cheap issue but not that expensive costs like for the P400.
Now we can look for a remanufactored 4L80e as the the cherry of the top of our rebuild.
Neighbour of our shop ask about the costs and the power of both trucks. He drives a Nissan Pickup.... 🤐
