M35A2W/W Brake problems
wiggall
151
Lenore, Id.
Saturday I drove THE BEAUTIFUL BEAST to meet up with some friends. When I step on the brakes, they would not release when I took my foot of the brake pedal! I had to dump the air tanks to get them to release! Any idea of what is going on?
ToddJK
4,518
Sparta, MI
Mine did that. I had to drain the air tanks, pump the break while the air tanks were recharging and no issues since. My guess is either the vent for the air pack to bleed off is blocked/plugged, or the air pack is going bad. Maybe see if you can get under there and see if it's clean around the air pack, wash it off with a hose and see if that helps. When it happened to me, the pedal was hard and only one brake was sticking.
Big Tom
114
Millington md
Also had that problem a wile back found the cup in the master cyclender had swelled just a little bit and was blocking the small return hole witch in turn would not let all the fluid back that pressure keeps the air pack engaged , rebuilting master cyclender fix the trouble
wiggall
151
Lenore, Id.
Thanks I will try that!
kenn
513
Texas
I know some poo poo them, but now is the time for a remote reservoir if you want one. I put one in when I put in my new master cylinder and it made both filing the master (cleanly!) and bleeding the line between the master and air pack a piece of cake. I also now have another thing to check before I get on the road as I do my walk around for any issues that might have arisen while parked since the last trip.
