New Dash Layout in the works……
coachgeo
3,477
North of Cincy OH
this one is hidden on the internet. I honestly cant find it anymore*. Conversion happened in OH loooooooooonnnnnnnggg ago.
*found it via reverse image search
ramdough
1,730
Austin, Texas
I have operated a few pieces of equipment with filter-minder gauges over the years. I have never fouled an air filter bad enough to ever activate one:)
I thought about removing it, but then I realized that the lower center hole is not really visible. If I cut a new panel ever again, I would skip that hole. For that reason, I am leaving it in the almost useless hole.
ramdough
1,730
Austin, Texas
Got my fording switch wired into my AC harness.
I won’t get all of my switches wired for a while, but I wanted to paint my new dash while everything was apart, so I inserted the switches where they go. Next task is to get the truck mobile again.
curious thing I found. P912 and J913 were unplugged and taped off. Is that normal? Why would they be loose like that in a dash?
Plasa
331
Italy
Sorry for my ignorance, what should be connected to P912 and J913? Maybe spare?
muddiver
WA.
thanks all! unfortunately the CNC plasma table was not perfect, so I will be filing every hole to make it all fit. I was close, but Murphy bit me.
I am still trying to decide what two gauges I plan to add.
I had planned on an extra fuel gauge for a secondary tank and maybe an EGT or transmission temperature.
anyone have any opinions?
Changing from a plasma to a laser to cut the panel that will give you a lot sharper and cleaner edges. But some shops require a little bit more money to do that.
ramdough
1,730
Austin, Texas
Well, installed my dimmer switch.
I have a slight interference on the new dash switches with some sheet metal. I clear the frame that the dash mounts to, but the sheet metal of the cab behind that ring is interfering. It isa minor trim, just going to take time to pull it back apart and correct.
coachgeo
3,477
North of Cincy OH
where is the camera looking? underside/backside of?? how do you reach that?
coachgeo
3,477
North of Cincy OH
I can reach it if I need to, but I don’t see myself adjusting it unless I am really in a dark place and need all of my night sight.
that works. OEM spot is in a bad location anyway. When you operate things beside it (light switch I think?) My hand would rub/turn it without my knowing it and after awhile wonder "hey... what broke??. why dont I have dash lights anymore??" Took me a while to figure it out. Others have reported same issue so Im only half stupid.
