wyocommo
- 6
- 8
- Casper, WY
I am looking for any information I can locate on a drivers side antenna mount for the LMTV/FMTV series trucks.
The curbside antenna mount is very common with NSN 5985-01-440-1322 (part# A3210717-2). I am searching for the drivers side version of this mount.
I think (but cannot confirm) that this is NSN 5985-01-438-2217 (part# A3210717-1) I cannot be positive that these are the correct #'s for the drivers side mount because I am unable to locate any photos or line drawings of these numbers.
Both of these mounts are a modified sugar scoop type that has a 'wing' for additional support on the back of the cab. They also have a taper on the antenna mount surface to offset the taper of the LMTV cab. These mounts are not the early scoop type mounts that attached to the rear wall of the cab but are located on the outside rear corners of the cab. See attached drawings.
View attachment curbside mount.docx
View attachment curbside location on cab.docx
I will be purchasing these driver side mounts if I can locate them.
Tnx in advance for any help!
