- 137
- 13
- 18
- knoxville tn
936 guys
a while back i install a pressure gauge to monitor pressure at the supply side (hi pressure) of the control valve body. after reviewing the TM's they showed a location to do exactly this - to monitor pressure - TM ( TM 9-2320-272-24-2 , section 3-389. PRESSURE RELIEF VALVE MAINTENANCE) shows the tap point on the right (as you look at it from the seat) center "tunnel" of the valve body. I installed a gauge at that point (the only tap on my valve body). the gauge (0 to 3000, new gauge) shows near zero pressure when running at all times - thought it should be seeing about 1350 psi. i have looked at the parts TMs to see if that showed anything else, no dice that i could see? back ground info, crane functions, but at times seems to be "slow" then run at other times run at what i think of as "normal". trying to figure out if pump is weak or i have a bad hose somewhere. i have check and replace the filter.
any ideas - bad gauge?
since the gauge was not working i had removed it (in picture) and was going to move it to the correct tap.... ha ha.. that's the only tap point.... so that's my dilemma. tap point is the shinny bolt
thanks
update on my post - a bit of playing around, verified the gauge is working and it turns out that tap point only sees pressure when one of the four controls is activated. reads zero with the pump running but no control is activated. If i crowd out - it reads about 150 psi, hoist up or down (no load) maybe 100 psi, will try the other controls and up date.
thanks
