ramdough
- 1,730
- Austin, Texas
Anyone have a source for these duckbill drains... mine are missing.My evaporator came with 4 duck bill drains so I installed them.
anyone else use 4? YouTube videos I saw only installed 2.
Mine were in a bag taped to the inside of the side area (under park brake buttons). Maybe check there.Anyone have a source for these duckbill drains... mine are missing.
It will be obvious when you pull the heater. The 4 pin connector matches the existing connector to the heater for fan power and panel illumination IIRC.I'm trying to sort out the wiring before I drop in my inside unit. I got the wiring harness from Tom.
Most if it makes sense one part plugs into matching plugs on the HVAC unit and has connectors for the fans, pressure sensors, and pump. Branching off this is a wire with a spade connector that goes to the fording switch.
That leaves a orange and a black wire on a 2 pin connector that seems like power and ground maybe... Not sure where these tap into.
Then... I see a round 4 pin connector in the HVAC unit that I don't seem to have a match for. I'm hoping it's something already in the dash.
The new two pin (orange and black) is additional power to your evaporator. The ends go to your power panel.I'm trying to sort out the wiring before I drop in my inside unit. I got the wiring harness from Tom.
Did you look for them like I posted above?Awesome, thanks for the info.
I always hate it when I get something all tore apart and find a surprise. Then you can't use it until you get it all back together, I hate that.
Now.... those stupid duckbill drains are the last thing in my way.
yeah, dug around in there with a flashlight... no luck.Did you look for them like I posted above?
I thought mine were missing too at first.
They are similar to what is on the heater unit. They are the flanges that the ducts which direct airflow at the driver and passenger foot wells are attached to. In my post I made a note that you must use the duct ring from the heater unit on the AC unit for the passenger side duct since the provided AC unit is too long and interferes with the transmission control module (at least on my A1R with the 3700SP transmission).Also, I have no idea what the "duct adapter rings" do or look like. Anyone have a pic?
I can't seem to find anything online in the way of a duckbill valve to fit those 15mm holes. Well I did find something but it was like a 12 week lead time from China.
