Grimbo
- 22
- 3
- Lenoir, north carolina
The 12v and 24v batteries have good voltage when measured at the batteries. The panel voltmeter has been dropping steadily and now shows less than 20v. Engine will not crank, only clicks. Checked all fuses, swapped relays etc, all good. Reading 24v and 12v on main points in electrical distribution panel. Not seeing any low voltages on relay power supply, both 12 and 24v. I redid all the battery cables/posts to eliminate on issues that side. When master switch is on, cab fan etc all blow strong(ie full voltage). Sometimes the engine will crank and it starts straightaway, so 12v side is good, but the 24v start circuit is where I think I'm having issues but for the life of me cant find it. Checked for loose connections behind panels etc. When the engine does run the voltmeter doesn't come up. Last time I checked alternator was charging on 12 and 24. Ran a ground jumper cable from battery neg to frame near engine, no change. I'm not an electrician so this is not basic for me. Anyone have any direct pointers to look at? Thanks
