Auxiliary fuse box?
ramdough
1,729
Austin, Texas
I am looking for a panel mount fuse box. One that would be flush with the panel face, have an easily removable cover, and conceal the wires and everything behind the panel.
What I am thinking is cutting it into the passenger kick panel.
Anyone see anything for this? I have looked and found nothing so far.
Also, please post what you did if you have a working solution.
Thanks!
Guruman
Not so new member
Thanks!
A quick search kicked up this, which seems almost flush mount...
https://www.amazon.com/Online-LED-Store-PSZACCEPS053H-Waterproof-Indicated-10Port/dp/B01N25TJV3/
Maybe look into marine breaker panels?
Guruman
Not so new member
I really like these Weatherdeck panels..... not exactly a fuse box, but waterproof-ish. breakers, indicators/labels. A fuse panel wouldn't have switches, but that might be a handy bonus to be able to turn off a circuit without pulling a fuse, and the switches are protected so you should be able to easily kick one. And they make them in 2-4-6 or 8 circuits. I might have to add one of these instead of the panel I have.
https://www.westmarine.com/blue-sea...cuit-breaker-panel-four-position-7808744.html
serpico760
1,751
San Diego, CA
Thanks!
I saw this while cruising eBay today
