After a deep dive in the search with vague terms, I figured I'd ask
I've had my M109 for over a month and well over 1000miles, the brakes are becoming a concern. They stop the truck and the pedal travel hasn't changed. Problem is: it's an inch off the floor.
I drained the air tanks, checked all the wheels for leaks, pulled the inspection plug from the air pack and purged it. Nothing obvious. Holds air and no leaks other than around the gauge.
Before I order $800 worth of shoes/wheel cylinders/air pack/etc.......where should I check?
Thanks!
Thanks!
