cucvrus
- 10,082
- Jonestown Pennsylvania
How about the modulator? is it getting vacuum? And is the hose tight going into the modulator? And being that you had the transmission out are you sure the metal line that runs down is not cracked or kinked. Check that also. I always take my CUCV's to a friend to get the vacuum modulator adjusted. That friend died during the pandemic and finding trustworthy mechanics that know older stuff is getting hard to do. I can figure it out sometimes it takes a while and several adjustments of the VCV on the injection pump. That VCV could be bad also. Take Care and Good Luck.
