I hooked everything back up and went to both ends of each side of the glow plug harness. Each side reads 24 volts when the glow plug is cycling. Isn't the card supposed to regulate it to no more than 16 volts? Well my new card from Hill Billy Wizard isn't. Need to have a word with them. Anyway. Not sure what's going on. I suspect the Resistors are bad since they are on a load and they are pushing 24 volts. Im pretty sure at this point all of my 5 year old or so glow plugs are toast. What do you think lol. I will check tomorrow. Trying to do this at the same time getting my garage and house loaded up with the movers.
Here my youtube of it cycling. I cycled the glow plug system twice. Each turn of the key the card cycled the through the glow plug relay 6 times. 24 volts then drops. cycles again to 24 volts and drops for a total of 6 times each time I turned the key to turn on the glow plugs. Hope that makes sense.
Any other suggestions? Can I bypass the resistor and run a 12 volt supply directly from my battery to the glow plug relay? Thanks.
ALSO can someone take a picture of a properly wired up relay? Batt side gets the hot wire from the relay. Orange side is the opposite side. The two smaller terminals get black/ pink and the other side gets what's left can't remember the color right now. Thanks.
I also just ordered a new set fo Glow Plugs. Should arrive by 3 pm Tomorrow/Sunday. My fuel shot off solenoid is clicking and I can feel it So I hope its ok if not Im not sure where people are getting theirs. I checked with NAPA AUTOZONE ORiellys and amazon. Amazon has something but I'm not sure its the right one without taking mine off. I will see how the Glow Plugs work. Hope I can just run a dedicated 12 volt wire from my front battery.......
