- 482
- 1,126
- 93
- AL
I am ready to tackle my last significant problem with the M1151A1. The auction photo below shows significant fin damage to the cooler. From the TM, I know the lower 1/2 is for the engine oil, the top 1/4 is for the transmission fluid, and the portion between is for the power steering fluid. Therefore the transmission cooler portion shows the most damage or restriction to cooling flow. I have driven it around the neighborhood and for somewhat short durations to check components and repairs but I am reluctant to drive any significant distance before fixing this issue. When driving, the cooling fan is cycling as it should and coolant temps are staying in a "normal" range. Is this concern valid or is this system over engineered especially while doing only neighborhood or moderate highway driving? I sure would hate to burn up a transmission.
