cucvmule
collector of stuff
- 1,164
- 596
- Crystal City Mo
Looks like I will drop the tank this weekend
Salty dog, since you have just recently owned the truck there is nothing wrong with dropping tank and confirm that supply is clean, water and dirt free. More problems are caused by contaminated fuel that progresses to clog filters, and ruin IP. On my civi 82 Silverado they put drain petcocks on both tanks to purge water from the tank at regular intervals. Why the military did not require is unknown.
I myself have dropped tanks on every car and truck I have ever owned because of buying fuel at stations that have contaminated tanks themselves. You never know when or where it can happen. Even new stations and tanks can get a load of bad fuel that goes out into the cars and trucks.
And also replace all rubber fuel line while you are at it. Even if it looks new do it anyway. The fuel line breaks down and particles of the hose will clog filter also. Most of the rubber hose is easy to get to, but the one behind the passenger fender well hardly ever gets replaced. And always check clamps for being tight. Small air leaks create all sorts of persistent problems.
Do it now and completely and you will hopefully have many trouble free years from fuel contamination. As Keith_J has said, "If you want a job done right" I do it myself.
And if there is any rust in the tank just replace it, they are not that expensive. I keep 2 extra here, one each side because of the fuel being sold at service station almost always have water in the systems. But I have 5 trucks that I drive, gas and diesels. Same tanks.
The straps almost always break but depending on how you do it you might not have to remove them. Drop by the saddles. Spray them up a day early might help.
