Oil filler neck removal
TexF18
34
omaha, ne
Trying to remove a leaky injection pump on a 6.5. I can't seem to get this neck off. Looks like you have to pull the pulley mounting plate off to be able to get the right clearance. Other issue is I'm having trouble finding the Tm for removal. I have only been able to find timing info
HoveringHMMWV
1,028
AL
Not sure what truck you have but with my M1097A2, I only needed to remove the serpentine belt to gain acces to the filler tube.
TexF18
34
omaha, ne
It's a m1123. Other question. So to remove serpentine belt. You put a 3/8 breaker bar on #7. The fan blade is perfectly aligned with that 3/8 hole and its too close. I even have a flat bar 3/8 for belts and it still can clear. Can engine be rotated from harmonic balancer or is a bolt going to shear off
Maxjeep1
1,912
Las Vegas Nevada
I just spun the fan by grabbing the blade. I had to modify a tool to get it off. CC7384AB-6A2D-48DF-A691-AAA7013B47B0.jpeg
Coug
4,241
Olympia/WA
Sometimes to remove serpentine belt all you have to do is press down next to the top idler pulleys and slide it right off. Can't confirm on yours with the belt going under both idlers, but on trucks with the Red Dot aircon it works easily.
TexF18
34
omaha, ne
I'll give us another go tomorrow. Tried pushing down on it earlier. Afraid I'm going to slip off it. Might try some Paracord and pull it down from underneath
TNDRIVER
458
Cleveland,TN
Remove the right inner splash panel to get to the tensioner to loosen the belt. The back side of the balancer has 3 or 4 large bosses that a wrench fits on to easaly rotate the engine.
  • Like
Reactions: OBX
jake20
843
Illinois
I did this yesterday on my friend's truck whilst yanking his injection pump, you've gotta pull the studs out so you can slide the plate forward. It was a lot easier on my M1043A2 with the Red Dot system, no annoying plate in the way, only had to remove the belt.
Basically:
- Remove belt
- Remove/loosen the 4 bolts holding that plate there
- Slide the plate forward
- Remove the filler neck
Check out the attached pics if you haven't gotten to it already.
