ActionStarCBRxx
- 1
- 6
- Hurst Texas
All,
I bought a new column with tilt and delay wipers. I am ready to install the new steering column and I got this wild hair up my arse to replace the rag joint.
So I bought the leather disk, and bought new bolts to attach the floppy leather to the coupling joint thingy. (had to drill out/punch the old pins) Now I am trying to put it all back on the steering box and attach it to the column shaft. I attached the rag joint to the steering box, and I can get one bolt in through to the steering shaft, but the other bolt won’t line up to mate with the other hole in the steering shaft.
I undid the bolt I had attached to the steering shaft and installed the opposite bolt, and now I can’t get the original bolt back in. With the rubber/floppy thing being new, it’s hard to keep it compressed into the coupling/joint.
The steering column is still loose and laying on the bench seat. It is not attached to the truck in anyway. I am starting with the rag joint first before tightening anything else up.
For a two bolt operation... this has turned into a PIA. Any suggestions or am I just a intellectually challenged.
Kelly
Kelly
