Chirider
- 3
- 3
- Chicago,IL
I now have opened the hood and honestly don’t know what I’m looking for. I did a search in the forum for access panel and no joy. So I am humbly asking for help again. Thank you and everyone.Check the ground in the access panel inside the hood.
Perhaps the access panel is in here? This is directly behind the light housing that I am having a problem with.I now have opened the hood and honestly don’t know what I’m looking for. I did a search in the forum for access panel and no joy. So I am humbly asking for help again. Thank you and everyone.
That cover as rusted as it is surely has let water in the wiring. Obviously you should replace the cover and probably the one on the other side as well. They cost about $20 each.Perhaps the access panel is in here? This is directly behind the light housing that I am having a problem with.
Pretty much, it is sending the signal to the light, 98% positive it is a grounding issue due to the symptoms.Silly question BUT can we be sure it’s not the switch?
Ahhh, No problem. Just a little rust, CAMOPerhaps the access panel is in here? This is directly behind the light housing that I am having a problem with.
The panel is behind the lights
Can you recommend where to source the access panel? Indeed , the other panel is also rusted badly. I’m doing a search and using words, “M998 front light access panel” and not coming up with anything on google or eBay. Thx for ur help.That cover as rusted as it is surely has let water in the wiring. Obviously you should replace the cover and probably the one on the other side as well. They cost about $20 each.
Another gremlin, coincidentally (I’m sure) after opening the access panel, my turn signals no longer work. The running lights work and brake lights work though. The light on the turn signal stalk lights up solid but doesn’t flash . In the past my turn signals would work intermittently so I’m not surprised. Could I need a new 3 lever switch?Silly question BUT can we be sure it’s not the switch?
