I left my panel light on the other night, after running the generator for a couple of hours yesterday I went out today to install a battery tender to find that everything is covered in diesel.
My return line is leaking rather badly and the fan is moving it all around.
After I picked up the generator I picked up 10' of 3.5mm line. I started taking the top off today and was able to unplug a section of the line, the shorter one from the side of the block to the 1st tee (the section that was leaking) #10 in the diagram.
Should I think of replacing the T's (#13), if so can you recommend a source?
Do I use a short section of the hose for #5 or is it safe to not touch #5 from the drawing?
I have taken the top off, and suspect that the back will need to get pulled off too to get the return line fully routed.
Thanks in advance.
