Mav’s M1088A1 Conversion
NDT
6,535
Camp Wood/LC, TX
The four super expensive Hawkers were dead and the flipper didn't know that they can be easily recovered with an AGM charger so he bought the cheapest Wal Mart batteries he could find and slapped them in the box as best he could.
Ronmar
7,488
Port angeles wa
what NDT said, they hooked up a new set in the rear two bays and disconnected the ground and 24v terminals on the hawkers. Just send it:) or pull the hawkers and see if they can be salvaged and insulate the two terminals on that cable that are attached to them…
Mavcaster
422
Maryland
Yeah so was trying to figure out if they essentially converted to two batts and just left the hawkers there or if a pos and neg terminal just needed to be connected to the hawkers. I found the diagram for the two batt setup which is what I plan to convert to but still looking for a 4 batt diagram.
Ronmar
7,488
Port angeles wa
Ok rog yeah I see it now. That lone terminal bottom right off the bolted together grounds threw me off but boy is it jury rigged…
Yea you can see its 24v counterpart taped over in the upper left behind the innermost hawker.
The quick fix to clean this up is get 2 thru-bolt battery terminals for the ground and 24v terminals. Ditch the 4 terminal cable and one of the 2 terminal cables. Use the other 2 terminal cable to connect between the 2 batts you are using And connect the 12v lead to a stud on the end of the 2 terminal cable…
Mavcaster
422
Maryland
I did notice the tape but wasn’t sure based on this sole photo. If that’s a terminal then that should share the pos post on the innermost everlast correct? If it starts then i’m assuming that disconnected 24v lead is coming from the alternator?
Ronmar
7,488
Port angeles wa
There are three 24v leads. One is from the nato plug, one goes to the polarity protection device/alternator and one goes to the starter solenoid. So those 3 leads will need to go to the + terminal of the innermost battery.
There is only one 12v lead and it can get connected to either end of the 2 terminal jumper between the batteries.
There are 2 ground leads, one from the nato plug and one to the shunt under the PPD and then on to the starter ground terminal.
Ronmar
7,488
Port angeles wa
looks like if a disconnect was on that single ground at the bottom... it would disconnect everything??
Sort of. If you only disconnect ground you will still have a difference of potential between any 12 and 24 circuits. The polarity protection device prevents any reverse flow from 24 thru any 12v circuits, but if you are working on anything there is still potential present in the circuitry.
coachgeo
3,463
North of Cincy OH
ok..... so the two Positives then instead in this case?
Mavcaster
422
Maryland
Ok well the plan is to head out on Monday and evaluate/hopefully get this thing on the road. I’m taking a truck full of tools/welder/compressor everything I can think of to try and nurse the truck home. Curious if anyone in MD or VA would be willing or knows someone who might be willing to lend me a towbar in case things go really south? I have lined up several contacts along my path where I can potentially leave the truck to return later with more parts etc.
