So if you don't want to spend hundreds on LEDs, but want to change away from the sealed fixtures, you can buy a pair of 7" round H4 housings, a couple pigtails to go from the stock housing to H4 ceramic plugs, and buy 24V H4 bulbs.
Below are some examples.
headlight housing. Make sure to find one that is DOT certified and not E-code (European version)
Expect $50ish range, plus some places have freight on top of that. The E-code versions can be had for a little less, but as I said, they are not certified for U.S. on road use (but as long as you have them aimed properly it's unlikely you'll get caught either)
wiring adapter:
bulbs:
Less than $20 for a pair shipped from Europe. Below is the link I've bought from. Had them in for 3 years/12k miles so far. Much brighter than the stock bulbs, but not quite as pretty of a pattern as the LEDs.
Find many great new & used options and get the best deals for OSRAM Truckstar Pro H4 Halogen Headlamp Bulb 64196tsp-hcb 100 Vibration Resist at the best online prices at eBay! Free shipping for many products!
www.ebay.com
So it's about $150ish to do the conversion with decent glass. You can find cheaper glass housings out there than the Hella and bring the price down a little.
The major upside, especially in your situation, is if you do burn out a bulb, it's only $10 each to replace them from now on.
