jplace1011
- 489
- 63
- Santa Ana, CA
We just installed a new Water Pump and a few other items. In the process we had to remove the Belts for the Power Steering Pump, etc.
After putting things back together, I heard a rattling sound from the Power Steering Pump. The Bolt that tightens the Power Steering Pump onto the Bracket, Drivers Side, was loose. So loose I can loosen it or tighten it with my fingers.
*It’s the one bolt that the Bolt Head is Facing/Pointing towards the Cab
According to the TM, there’s no Nut for that particular Bolt.
So do I just simply tighten it with a Socket and Ratchet? Does it need thread locker?
Thank you in Advance.
