Differential options
Vapor Trail
264
Kentucky
What kind of locker or system should I put in my differentials front and rear? I mostly drive in the street but want maximum traction for snow or off road also. I was thinking electric lockers front and rear but it may not be necessary to go to that expense. I’m not really even sure how the OEM system operates
4,820
The HMMWV uses torsen diffs. While they're not as good as a locker, they're way better than a open diff or a limited slip diff. You can use the brakes to modulate the diffs when they start spinning to apply power to the wheels that still have grip. Outside of that, there's the auburn gear ECTED diff. Which allows you to have a limited slip and a e-locker.
TOBASH
3,498
Brooklyn, NY
I never explain it properly. Look up BTM Brake Throttle Modulation IIRC. Patracy is referring to that.
Vapor Trail
264
Kentucky
OK thanks guys. i researched torsen diff and the BTM method. It looks like the BTM method is something that is not ideal and I wouldn't want to have to rely on becaue it can tear stuff up and doesn't give 100 percent of power to the right wheels. Someone said the Auburn is not recommended for use in a vehicle that is driven on the road the majority of the time. I think I'll do an ARB or Eaton locker.
Maxjeep1
1,916
Las Vegas Nevada
I want a Detroit Locker for the rear. They get a fair amount of hate because of their on road manners. You would probably be just fine with the front and learn how to brake properly as suggested above.
Maxjeep1
1,916
Las Vegas Nevada
I don’t like to rely on air compressor, plastic lines and switches. OX locker is a cable I believe and has less moving parts. I think the ARB is a fancy Jeep thing
TOBASH
3,498
Brooklyn, NY
HummerH1 has almost 300,000 miles on his A0 rig that goes offroad in ice, snow, mud, rocks… Never once has he indicated that he wants or needs lockers. I have predominantly street vehicles both HMMWV and H1. I have NEVER wanted lockers.
These are amazing capable vehicles As-Is. I’m not sure what you’re looking for.
Coug
4,360
Olympia/WA
I've done some decent off roading in the Jeep parks on trails I didn't fit in.
With BTM I've climbed up rocks while literally balancing on 2 wheels (opposite corners)
It's not as good overall as real lockers, and a little noisy because my brakes like to squeal a little, but unless you're trying to build a true rock crawler or off roader like that, as opposed to occasionally doing some light to moderate trails, then it's a lot of expense that doesn't give much additional benefit
98G
Former SSG
4,450
Emphatically this!
I like selectable lockers. But the stock M998 when used with compence won't get stuck due to lack of a locker.
I contemplate a Detroit locker for the mid axle on my M925, but again, I've had it in soupy mud spinning all 6 16.00's. I doubt I'll encounter a situation where the locker makes the go/no go difference. And the on road manners are a pretty big downside.
We've had two Jeeps with electronic selectable lockers. I've engaged the lockers exactly once, and this was when deliberately seeking out such a situation as a teaching moment for my GF.
If I were to add a locker to a HMMWV, it would be selectable. But BTM is more than sufficient.
TOBASH
3,498
Brooklyn, NY
I have videos of Hummer H1 two and three wheel driving with his A0 and 7k axles.
Lockers! He don’t need no stinken’ lockers!
  • Like
Reactions: 98G
