Thumper580
- 210
- 43
- Virginia
I've looked and can't find it, but what size fire extinguisher goes on the floor bracket next to the drivers seat?? 5lb. 10lb. Thanks.
Thank you!AMEREX B500 5lbs ABC
Fits the existing bracket?I use a 5lbs Halotron.. if I do have to use it, I don't want that powder everywhere.. Have the same one in my Jeep as well. (Switched from the powder ABC to halotron after I watched someone at a car show put out a _small_ engine fire, and more or less fill their intake with powder...)
Depends what you mean by bracket. My HMMWV had the plate with the hole and the support on the floor but not the strapping. The fire extinguisher I bought was for Marine / DOT applications and came with a new strapping/bracket which I mounted to the existing holes in the plate.Fits the existing bracket?
I just checked, it's not a 5 lbs, I put a 2.5 lbs in the HMMWV. (The 5lb one should fit, but I've not tried it.). One I used was from an Amazon reseller:
Amerex B385TS, 2.5lb Halotron I Class B C Fire Extinguisher
I think it's smaller in diameter than my bracket is designed for.
