Remind me the routing for the CTIS harness?
ramdough
1,729
Austin, Texas
So, I just installed my winch/auxiliary harness into my dash…. Getting ready for my evaporator install.
does the CTIS harness route from under the dash in this hole from the center area?
Ronmar
7,431
Port angeles wa
I dont think it goes all the way under by the gas pedal. I think it turns toward the rear just before that, under the park and trailer air controls and comes out a hole in the side of the box below the park control. Then it goes around that front corner and right up to the side of the CTIS controller.
U is the speedometer input from the transmission, S is the overspeed signal to the dash light.
What does the CTIS controller side of the connector look like?
ramdough
1,729
Austin, Texas
thanks for the info….. here it is. This CTIS controller may not be original…. @fuzzytoaster ?
ramdough
1,729
Austin, Texas
can you please Post a picture of where it comes out? My evaporator hopefully has the same hole.
Guruman
Not so new member
FWIW. My old heater unit had a hole in the side right where my right knee is when driving (maybe lower). The wire came out the side panel near the lower rear corner of the unit, and ran around the corner to plug into the CTIS control.
The new A/C unit did not have the same hole, so I drilled one and installed a rubber grommet.
