coachgeo
- 3,463
- North of Cincy OH
appreciate the info. Neat trick.So how did I prime my fuel filters after changing them and discovering my primer bulb doesn't work??
(665) FMTV LMTV MTV fuel prime issue and sending unit replacement. - YouTube
IMHO add a 12v inline; petrol type is fine, aux fuel pump as close to the tank as you can and put it on a switch. This can be used to prime and can be used to get you by if you get an air leak on a trip. In that case you just leave it on.
Your hand primer not working is a sign it leaks air. You will need to replace it cause it will leak air into your fuel when driving and sitting.
