loosegravel
Just a retired mechanic who's having fun!
- 504
- 891
- 93
- Enumclaw, Washington
Good morning. I'm learning more about these wonderful machines all of the time. In the past 4 years or so I've had a variety of the 8XX series of generators go through my hands now. I recently brought home (2) of the MEP-804A units on trailers from Hermiston, Oregon. With these (2) units I've now had about (6) of the 15kw units. I always appreciate the help and support that I get on this forum.
I have always replaced the fuel well nuts on these generators when I get them home. It's an easy upgrade using the 3/4" bulkhead fittings with 1/4" NPT threads, backed up with steel washers and neoprene washers. But much to my dismay I've had fuel leaks on a couple of these 15kw machines even after the fuel well nut upgrades. I discovered that the fuel leaks only occur when I'm pouring fuel into the main on-board tanks. Ultimately, I removed the fill neck assemblies and discovered that the angled rubber sleave which connects the upper fill neck to the tank is rotten. In looking at TM 9-6115-343-24P, page #98, figure #13, item #15, I can see NSN 4720-01-392-0319, part #88-22068.
Oshkosh Equipment seems to be out of them. I could run a parts request quote through WB Parts, but I was first wondering if any of you have been able to source them a different way or come up with a sufficient substitute like you did for the fuel well nuts?
Thanks as always!
Jeff
Thanks as always!
Jeff
