JasonS
- 144
- 63
- Eastern SD
I purchased a deuce differential assembly with the intent of installing an ARB air locker, then swapping that with the one currently in the rear of my bobbed deuce.
The ring to pinion backlash is ~0.020" versus the spec of 0.005" to 0.015". While there are shims that can be removed to move the ring closer to the pinion, my question is whether this amount of wear is acceptable/ normnal and if I should simply adjust the depth with the shims or look for something in better condition. There is nothing otherwise or obviously wrong with the ring/ pinion to my untrained eye. The bull gear backlash is in spec.
Thoughts or suggestions?
