M35A2 Air Assisted Power Steering Questions???
WhoMe08721
123
Bayville/NJ
Hey Guys,
I was thinking about installing a AIR O-MATIC air assisted power steering on my truck. But wanted to know some thing before buying and install one.
1) Is the AIR O-MATIC air assisted power steering worth the money???
2) Is the system reliable? and if the air cylinder fails when driving can you still steer the truck??
3) Has any one have issue with water in the air system with this system??
4) What the going price on a used system and NOS system?? I found a complete working used system for $1,200.00. Is that a good price???
5) What should I look at when buying a used system??
6) Are they hard to install??
7) Finally opinion on the over all system???
Floridianson
2,511
Interlachen Fl.
Been awhile but. Make sure you have a air cut off valve to the unit starting at the tap. It was said run the regulator wide open so it that's true you do not need the regulator. Instead install small water catch type of filter set up.
runk
66
Houston, TX
Here is a not too distant discussion with some good links -
My opinions (FWIW) on your questions-
Depends on the money, when a bunch of them were on the market 10-15 years ago, absolutely ! Recently new sets have gone for crazy money, maybe more then paying someone else to install a conventional power steering conversion.
System is reliable, and when it fails you are just back to the no assist configuration. But, the pressure protection valve is essential to preserve brake air if there is a leak in the steering.
Maybe. There have been some discussion on what causes failures in the non- serviceable drag link/actuators, and water contamination is a possibility.
That is pretty similar to what NOS systems were going for 10-15 years ago, when they were more available.
Drag link/ actuator is functional !!! Pressure cylinder is usable. Other mechanical mounts are present.
Drilling the hole through the frame for the air fitting sucks.
I love mine, maybe not as good as a hydraulic power steering conversions but way easier to install. Saves my poor old arthritic elbows
F-Twelve
Meridian, ID
Hey Guys,
View attachment 885273View attachment 885274View attachment 885275
Great questions and pics. I just bought a air-o-matic (used) from Boyce in Utah for $1,200. Now it's install time. Do you have any additional pics of your install? I'm doing homework right now and I'm happy to post pics too once I get started. Thanks in advance for any additional info/pics.
sue
364
tulsa OK
We put a hydraulic steering on ours. And of course if lose the engine or hydraulic fluid you still have steering just a little harder. Search our post and maybe that might help answer some questions. And from our profile picture you can see we put the 53 inch tires on. And would not change the steering feel by and ounce( beginners luck!)
WhoMe08721
123
Bayville/NJ
I never got the air-o-matic it sold before I could get it
F-Twelve
Meridian, ID
Could you post some pics of your hydraulic steering system? Much appreciated in advance
sue
364
tulsa OK
Sorry we live in Tulsa but had to last minute be in fort Campbell, but will be back early next week and will try to get pictures. If you can message me after next Monday and we can can exchange pictures and any questions you might have
