3116 Engine block material
tgreening
94
Canton/OH
I’ve gotten conflicting answers. Who has definite information on the material the 3116 is made from, cast iron, or steel?
87cr250r
1,988
Rodeo, Ca
It's iron. Need one repaired? Welding is problematic. Check out www.locknstitch.com They're masters of iron block repair. They are small engine affordable despite the big projects they brag about on their website.
tgreening
94
Canton/OH
Yep, welding cast iron can be a bitch, but I imagine by the time I shipped an engine out to California and back plus pay for the repair, I could have probably just bought another engine.
simp5782
Feo, Fuerte y Formal
9,385
Mason, TN
It's not hard just gotta get it hot enough. I drimmel the cracks out to make it cleaner to weld
87cr250r
1,988
Rodeo, Ca
What exactly do you need repaired? I have a few outside the box recommendations depending on the repair.
Also, LockNStitch sells the tools to DIY your own repairs. They aren't terribly expensive, figure $300 to get your foot in the door on tooling plus pins.
tgreening
94
Canton/OH
I’ll post up some pics, it it would probably be past my expertise level. It’s at the back of the block on passenger side, runs out of one of the oil pan bolt holes, up the block and around the back of the block, parts unknown. It’s the around the curve part that’s probably outside my experience level.
87cr250r
1,988
Rodeo, Ca
That is 100% a LockNStitch candidate. I would never consider welding that. The big question is, what do you think lead to that crack? The initial condition needs to be addressed prior to repair.
I would consider an epoxy repair if it was simply the water jacket but I don't like that it extends through the pan rail. That's a structural part of the block.
The block is available from Cat, $4700 🤕
