Broken bolt of my CUCV M1009 please help identify where it came from!
Steel Hunter
27
California
I need help identifying a broken bolt off my CUCV M1009. I found today in the driveway today. I closed the door after returning from work and I heard it hit the ground. Can’t seem to figure where it came from, I looked everywhere. It has the letter I and 9.8 stamped on it. See attached photos
87cr250r
1,982
Rodeo, Ca
It's an easy fix. This is one of the situations where an EZ Out is supposed to be used. Drill a hole in the middle of the bolt and use the EZ Out to unscrew the remains.
As for a starter, if you can get your hands on a real Delco-Remy 28MT, new or reman by a trusted supplier, that would be your best bet. If you see a good deal on a SAE mount starter you can swap out the nose cone for the pad mount GM style. My local starter shop just charged me $14 for a new nose cone.
cbrTodd
479
Indianapolis, Indiana
Lots of good advice here! Also be sure to use the starter tail support if using the big direct drive starter. It will break bolts again quickly without it, at least from my experience on gas engines.
I have had to do the ez-out process on a gas big block before and it was aggravating to get the drill bit centered up. I made a jig out of part of the old bolt to keep the drill bit straight. Helped tremendously with preventing damaged threads.
Steel Hunter
27
California
Thanks you for the info, I’m going to give it a go this weekend hopefully. I’ll let you know how it goes. Thanks for the response. I really appreciate it.
