1088logtruck
- 45
- 13
- Hartland, CT US
Having to find a short to ground on a ground switch circuit is something I'd never had to deal with till this definitely makes it difficult
CB70 terminal 4 feeds two 1586 wires, one to px15, (main light switch) and px17 (ignition switch). Could the main light switch be bad?Basically now when the trucks master switch is on or it's running it'll stay running till you turn the lights on then it'll blow cb70 and shut off.
Ya main light switch was bad you were right but I bypassed it to a regular toggle....now I have power at 2 of the brake switch terminals again but as soon as I hit the brakes it blows cb 70 and cb76 and shuts off....also noticed the lowest of the three 4 pole diodes on the panel melted a little bit.CB70 terminal 4 feeds two 1586 wires, one to px15, (main light switch) and px17 (ignition switch). Could the main light switch be bad?
px15 is a connector (Main Light Switch), not a wire. (TM 9-2320-366-34-1 (3 of 40)) K is wire 1404. I think 1 k6 wire goes to the light switch and one goes to a large connector on the bumper... Which is grounded? The light switch wire or bumper (j51) wire? Damn, i'm getting confused...Also of the 2 output wire from relay k6 one has short to ground the other is open. If I remove the grounded wire it won't blow a fuse but still no brake lights. The px15 k wire is short to ground.
If you unplug J51, does the fuse blow?px15 is a connector (Main Light Switch), not a wire. (TM 9-2320-366-34-1 (3 of 40)) K is wire 1404. I think 1 k6 wire goes to the light switch and one goes to a large connector on the bumper... Which is grounded? The light switch wire or bumper (j51) wire? Damn, i'm getting confused...
It is always something STUPID right.. Welcome to my world. If my brain made no mistakes... my brain would not be working at all..... ended up being that I had the trailer plug wired wrong and the brake wire was grounded in the trailer plug....
So Im having a similar issue as of yesterday ... Previously they were working great But I noticed the other evening the brake lights stopped working,Brake lights get prime 12v power from the main switch. It has to be on to power K6.
with the main sw on you should see 12v on one terminal of the brake light switches. It flows from switch, past K2, thru CB76, thru the coil of K6 to the brake switches.
So how would I bypass it if needed ? I did a test on DA1 and it also had power . Maybe I should check the K10 relay againK6 is a good sign, means the switches are OK. from K6 it passes thru the light switch and activates K10. K10 switches the light output from flasher to brakes. Flashers working means K10’s de-energized contacts(30-87A) and all the rest of the light circuit is also OK. So I suspect you have someth9ng a iss with the circuit thru the main light switch. That one is easy enough to bypass, and turn it into a brake light system more like a normal vehicle(brake lights work at any time)…
here is the A0 light circuit I drew showing it all on one page
