AndyV
- 4
- 3
- Golden, CO
My M1123 showed up with no windshield. Are there any previous posts or information on parts needed? Right now its just a A pillar.
Man, Thats a Good Deal ..If you need just the glass, they are $41 each piece from AMG.
It was even better back at Christmas time.Man, Thats a Good Deal ..![]()
They’re out of stock at AMG for the glass.If you need just the glass, they are $41 each piece from AMG.
H1 glass and seals are the same part numbers (clear glass). The H1 also had glass with tint strip at top. Those are RH and LH. The clear is same number for both sides.The glass is simple sheet stock windshield that can be cut to size with a pattern at any truck glass shoppe. You will need to make seals out of rubber and then reenforce with silicone windshield grade stuff. I would do that rather than wait for months on end to get the rig on the road.
You can also try H1 glass and seals. I am not sure but I bet that would fit.
They are always out of stock on things, even if they show having them in stock.They’re out of stock at AMG for the glass.
I’m in the same boat, no windshield (I knew that). Looking for entire windshield kit (glass, seals, retainers, hardware etc).
Does anyone know if this will this fit a 1165a1? Glass was removed during the demil process. Serial number 25x,xxx. ThanksI found a windshield kit on ebay for $300.
Listing detail (from ebay seller oemparts99
This listing is for a set of 2 pcs of Basic Laminated Windshield Glass with 2 Weather Strips, 2 Glass Retainers, 1 Center Retainer and 16 Screws for M988, HMMWV. The same glass fits both Left and Right side of the windshield. The Glass is DOT 1029 approved and 1/4 inches thick. This kit fits on all HMMWV M-series vehicle including M997, M998, M1035, M1037, M1038, M1097, M1123
2 pcs 12339514
9340-01-185-3757
2 pcs 12338941
5330-01-209-5997
2 pcs 12338852
2590-01-189-1067
1pc 12338843
2590-01-188-3225
16pcs 9414241
5305-01-361-5353
same basic frame...If kit comes with the bezels....you will probably have to redrill window frame and use self taping screws for bezels.Does anyone know if this will this fit a 1165a1? Glass was removed during the demil process. Serial number 25x,xxx. Thanks
I'm not positive about the m1165, but I know m1151's use a different windshield retainer than an m998. It's very similar, but its thicker aluminum and the holes are in different locations. It attaches with bolts, not self tapping screws.Does anyone know if this will this fit a 1165a1? Glass was removed during the demil process. Serial number 25x,xxx. Thanks
Does anyone know the Nsn’s for the new style retainers are?I'm not positive about the m1165, but I know m1151's use a different windshield retainer than an m998. It's very similar, but its thicker aluminum and the holes are in different locations. It attaches with bolts, not self tapping screws.
If your windshield frame has threaded inserts I would make sure to get the newer style retainer so you dont have to drill any extra holes.
I would just call Craig at Mac Motors, he'll know.Does anyone know the Nsn’s for the new style retainers are?
X2 on the siliconeThe glass is simple sheet stock windshield that can be cut to size with a pattern at any truck glass shoppe. You will need to make seals out of rubber and then reenforce with silicone windshield grade stuff. I would do that rather than wait for months on end to get the rig on the road.
Called, could not get a straight answer....I would just call Craig at Mac Motors, he'll know.
