Skipper M1088
- 10
- 3
Hi Soldiers,
So glad I found this site filled experienced and knowledgeable people. I'm hoping you can help.
I purchased a non running 2001 M1088A1 from Government Planet. Everything appeared to be there and hopefully functional with the exception the alternator pully, voltage regulator and the power distribution panel box cover. I was able to find an alternator pulley but still need a voltage regulator and would like to find a power distribution box cover. Does anyone know where I could purchase one? I have attached photos for reference and to share.
Not sure if the alternator (C.E. Niehoff N1511) is in working order either? Can it be tested without the voltage regulator? Is the alternator rebuildable or available separately? If rebuildable or available separately, does anyone have a regulator (C.E. Niehoff N3207 I believe) they would be willing to part with or know where I can purchase one.
I have been trying to find a wiring diagram specifically for a 2001 M1088A1. It appears there should be two wires and the 6 pin plug connected to the voltage regulator? 1. The 28 volt exciter wire from? 2. The sense wire from the C.E. Niehoff N2003 Load & Battery Control Device. 3. 6 pin plug from the alternator. I can't find the second wire to the LBCD under the hood and the wiring harness doesn't appear to compromised in any way. I found a photo of another 2001 M1088A1 with only the 28 volt exciter wire and no sense wire. Every wiring diagram I have seen shows the sense wire? Does anyone know if the 2001 M1088A1 doesn't use or need the sense wire to the LBCD. I have attached some photos and diagrams for reference. The last photo will be of the photo of the running 2001 M1088A1 I found on the web without the sense wire.
I have included a photo of what I believe to be the LCBD? Can anyone confirm?
Driveshafts were also disconnected? I assume they were disconnected so the brakes could be aired up and it could be moved around? I have aired up the system from a compressor and cant get the brakes to release. I haven't tried to cage the brakes and beat them to get them to release yet. Any suggestions would be appreciated. A few of the brake shoes appear to be cracked or broken. Does anyone know where I can find new brake shoes?
Any help would be greatly appreciated. Thank you in advance. Happy Holidays!!!
