acudanut
- 42
- 18
- Gardner, Ks
How fast can a 2001 HMMWV go ?
My A2 runns great an germany interstates with 70 to 75 mphHow fast can a 2001 HMMWV go ?
Show Off !!!My A2 runns great an germany interstates with 70 to 75 mph
Yes, the turbo has a higher rear end gear ratio than the NASo the A2 is faster than the turbo REV truck which has 30 more hp?
Speed and horsepower are apples and oranges. Speed is about distance over time. Horsepower is about Force over time. Horsepower will allow faster acceleration but gearing ultimately decides top end speed.So the A2 is faster than the turbo REV truck which has 30 more hp?
Not at all true,,,,Speed and horsepower are apples and oranges. Speed is about distance over time. Horsepower is about Force over time. Horsepower will allow faster acceleration but gearing ultimately decides top end speed.
Not going to happen unless you are going down hill, even with 30 more HPAS I said, it is a 2001. So it would have a 6.5 4 speed. I want it to pull a horse trailer and go about 70 mph... How many Humvees had turbo's ?
Sorry Mog, BUT ultimate speed is limited by ultimate engine RPM and gearing. Yes, you need some horsepower to push, BUT in our vehicles it has to do with gearing not HP.Not at all true,,,,
You can have all the gears you want but if you do not have the horsepower there will be no speed just bog.
Otherwise we could set world speed records with lawn mower engines, it takes horsepower to go fast, that is why as aerodynamic as a Bugatti is it still takes 1000HP to push it to 250MPH, Interestingly only 500HP to push it to 200MPH, they say transitioning from 200 to 250MPH is like transitioning from pushing the vehicle through air to pushing it through water.
Can it do 70? Sure. Can it do that towing? It might be able to get UP to that speed towing. But it's not going to be happy doing it. And your wallet isn't going to be happy trying to do it with diesel being $5 a gallon or more. You'd be better served with a civilian truck than what you're trying to do.AS I said, it is a 2001. So it would have a 6.5 4 speed. I want it to pull a horse trailer and go about 70 mph... How many Humvees had turbo's ?
Swapping to 2.56 gears will make it worse, you can in theory go faster but that Detroit ain't got the guts to pull a horse trailerChange your diff gears to 2.56. I think pulling a thousand pound house in a thousand pound trailer that will act like a sail would make 70MPH unrealistic in a HMMWV with stock tires. Swapping to 40” might help.
Its got EVERYTHING to do with power and the Detroit just does not have it.Sorry Mog, BUT ultimate speed is limited by ultimate engine RPM and gearing. Yes, you need some horsepower to push, BUT in our vehicles it has to do with gearing not HP.
