J.O.A.T-M.O.N
- 9
- 3
- Idaho
I've finally got the motor in and am ready to apply power. With the starter switch off (and through process of elimination disconnected) as soon as I connect the negative wire to the battery the starter kicks in and cranks the motor. I'm suspecting a bad smart start box but would like to dig in further before spending the money on a hunch. It's a 6.5L non turbo th400 m1097a1. The box is a KDS CR-2700. I have never had this truck running as of yet. As I am trouble shooting I have disconnected the trigger wire to the starter (74A) and hooked up a test light so I'm not arching the battery terminal. I've gone as far as disconnecting the interior cannon plug from the start box and when I connect the battery I still get power to wire 74a. If I had board level schematics I could go further into testing the system but without those its just a magic box. What else could trigger it to power the starter? What other info would help in figuring this out? Thanks!
