New member from NM
NM 1078
15
New Mexico
Fairly new to the page. I recently picked up a 2003 M1078A1 with 8k miles on and traded in my 2016 Ram that i had built out for camping. So far everything has been going well with it, even with it being a daily. I installed a block heater which has been a life saver. I did have one question for anyone who might have some info. Periodically my check engine light pops on and then turns off after a few seconds. Does anyone know what might be causing this?
Cheers
flyfishtrailer
1,040
Cool, CA
Cheers
Welcome...I suggest you start a new post in the FMTV forum to get your question answered. It may not get noticed here in the New Members area
19,737
Cheers
Welcome to the Outfit!
It might be worth spending a weekend sitting in the right seat and going through the fuse panel cleaning it up. Before you start, disconnect the batteries! What you want to do is clean the contacts in the board. The windows aren't always rolled up when it rains and the creeping crud slowly takes over. Use a small brass toothbrush and then apply a little Anti-Oxident paste.
And while you are here, grab yourself the TM's (Technical Manuals) for your truck.
NM 1078
15
New Mexico
Thanks, I'll make sure to do that this weekend. The previous owner did tell me there is a leak on the passenger side coming from the overhead marker lights so that water may have messed with the contacts. I need to fix that light along with the other small stuff.
Swope
New Jersey
Cheers
Welcome to the club
