Hi
I have 1986 cucv m1028, and im going to add antoher fuel tank on the passenger side, the parts that i have oredered are:
-The tank
-Hardware to mount it to the frame
-Fuel hole in bed (cut from donor truck, welded to my bed), fuel filler neck and everything to put fuel in the tank from the passenger side.
-Spectra premium fuel tank sending units FG05L
-GM Genuine Parts D7003 Fuel Tank Selector Switch
-ACDelco U7001 Professional fuel tank selector valve
-WVE by NTK 1P1132 fuel tank selector valve connector, 1 pack
The original fuel sender on drivers side has 3 ports on fuel sender, so i ordered fuel sender on passenger side with 3 ports, hope that works.
So my question is how to plumb both tanks to the fuel selector valve and the how to wire the fuel tank switch in dash to the fuel selector valve connector. I tried to order as many oem parts as i could so i would not have to invent the wheel all over again, so hopefully i can get straightforward diagrams or something along those lines.
-The tank
