MTVR towing capacities
tnjtransport
Gypsum, CO
Good evening gentlemen. Thank you for adding me to your group. I have tried scouring the web, and this awesome site, and I am unable to find what I am looking for. My questions:
1.What is the maximum rated trailer towing capacity for the MK23, and the MK31 tractors in the 2000 model year?
2. where can a fellow find the replacement driver and passenger doors?
Thank you
flyfishtrailer
1,100
Cool, CA
Check in the TM section and locate the operators TM. If they are available to the public, they will be in there
DeMilitarized
1,068
Gainesville, GA
@Elijah95 has a youtube channel that can help you with your MTVR on things that aren't in the limited TMs avalible check out "The MTVR Channel" on youtube. Second, doors are currently being worked on being manufactured by multiple parties on Facebook Groups trying to replicate them. Patience or lots of money is the only way to get your hands on doors. Also it is $14k for doors from oshkosh.
Elijah95
Certified Rookie
1,240
1,211
Georgia
0A3F8F55-271A-4935-BF9F-4C864D775921.jpeg2FA88B2E-6BFB-4F28-870B-F71D61F6D4DA.jpeg851E90B4-467F-4F7F-85DB-ED6AB883DA74.jpegJust dug through that manual and towing capacity isn’t mentioned. However I can say, my MK23 cargo truck has a data plate for 20,000 towed glued to the door however i believe verbiage may not be detailed enough. The pintle is reinforced much better than a M939 series truck, and I’ve personally pulled 47,000+ Trailer and cargo weight with an additional 5000 in the bed without issue, truck handled excellent and the trailer has full air brakes as well so stopping was not an issue whatsoever. So i believe the 20k max should be written as tongue weight, because the one time I loaded a wrecker backwards on my pintle trailer overloading the pintle of the truck it lightened up the front end substantially.
TacMac2012
136
Wallburg, NC
I have the doors listed on ebay, I would discount a little if purchased direct from me. Yes, they are expensive. I have three pairs of doors left that I don't currently have trucks to put them on, I will likely sell only 1 set in case I buy another MTVR or two. Basically ALL the trucks are being sold now WITHOUT doors. I have yet to see ANYONE with doors aside from the right side doors that have sold at auction recently, and once pair of those brought close to what I am asking for a L&R pair.
As for what the truck will pull, the answer is PLENTY.
serpico760
1,878
San Diego, CA
Might be a good idea to make good measurements of those doors at least good enough that somebody can fab up something that'll work good enough. Then people can use those plans to make new doors or have them made by somebody. Perhaps some industrious fabricator can start making those doors on the side and selling them to the people who bought doorless trucks! Even better have them 3D scanned in addition to just being measured.
GILBERT2020
59
MARSHFIELD, MO
View attachment 887847View attachment 887848View attachment 887849Just dug through that manual and towing capacity isn’t mentioned. However I can say, my MK23 cargo truck has a data plate for 20,000 towed glued to the door however i believe verbiage may not be detailed enough. The pintle is reinforced much better than a M939 series truck, and I’ve personally pulled 47,000+ Trailer and cargo weight with an additional 5000 in the bed without issue, truck handled excellent and the trailer has full air brakes as well so stopping was not an issue whatsoever. So i believe the 20k max should be written as tongue weight, because the one time I loaded a wrecker backwards on my pintle trailer overloading the pintle of the truck it lightened up the front end substantially.
Good memories on this one man. Just glad you made it back home safe.
sneaky3531
Cove, UT
I wish I would have taken pics of some of the loads I hauled and towed behind MTVRs in the Corps. Used to pull an EET trailer loaded to the gills with pallets of 155 rounds, powder, and the bed full of pallets of 50 cal and 7.62 ammo. Needless to say, it was well over what that data sheet says lol.
Sent from my SM-S918U using Tapatalk
gring
TN USA
Hello! Does anybody know what the pintle height is off the ground? Just bought a MK29, but have not taken delivery. I'm trying to see if I need to custom build a trailer to compensate for a higher pintle hitch. Right now I can only find trailers that go up to 32" off the ground for the lunette. Thanks!
Ellis6
Oregon City, Oregon
My MK23 Pintle height is 40 inches. It’s been a while since I made the measurement, but I assume its to the center of where the ring would sit. Goodluck with the new purchase.
Dirk
dlynes
37
Augusta, Georgia
I am also trying to find out what the GCWR's are by variant.
I have a 2001 MK25
GVWR 62,200 lbs
GCWR ?
Actual Vehicle Curb Weight (VCW) 28,020 lbs (Listed VCW 28,642)
GAWR 65,000 lbs
FRONT 16,000
MIDDLE 23,500
REAR 25,500
Max Cargo 30,000 lbs
Max Trailer 22,000 lbs (seems extremely low considering my 1 ton, single rear axle is Bumper Pull Max Weight is 20,000
& 5th Wheel is 21,700)
DeMilitarized
1,068
Gainesville, GA
I have a 2001 MK25
GVWR 62,200 lbs
GCWR ?
GAWR 65,000 lbs
FRONT 16,000
MIDDLE 23,500
REAR 25,500
The pintle is a 50ton pintle. Buyers rates a 20k vertical load on their 50 ton so 20k tongue weight let’s call absolute max. If you had the right trailer and weight distribution I’m sure your gcvwr could be as high as 150-160k.
dlynes
37
Augusta, Georgia
I wonder what DOT would go by? I believe the tires are rated at 14,540 each or combined weight of 87,240 lbs.
DeMilitarized
1,068
Gainesville, GA
Legally your openly allowed to tow 22k by dot standards and anything more is a citation. If you don’t already have your class a or e in Georgia you’re also violating the law.
