Show me your generator shelter
Evvy Fesler
772
Roxboro, North Carolina USA
This is mine for now. :LOL:
Until I get the set mounted on a pad and hard wired to the house, I'm not building anything.
Hoping to learn something by asking this question. Please don't take it as being critical. I really want to see if there's something that I should consider with my generator set. Poorly worded as this question may come across, please forgive, but... why temporarily cover a device that's designed to withstand all kinds of weather?
shazam
51
13
Ohio
Valid question indeed! My personal sad, but true, answer....anal retentive! :cool:
shazam
51
13
Ohio
LOL - me too! I put a tarp over mine and laughed at myself. I was standard issue GI and they gave me a poncho so I guess it's acceptable to cover a generator! Besides... making sure rain water stays out of the muffler system can't be a bad thing.
I got a foot-long piece of matching thread pipe, and added a tractor exhaust cover. It sits flat on the end of the pipe, and when the gen starts the exhaust pressure opens it....easy peasy!
Jim
Evvy Fesler
772
Jim
That's great...!! If I ever build a roof over mine, which we hope to do someday to help it blend into our rural residential environment, we can run the pipe up through the roof using some sort of rain collar. I imagine that the hearth suppliers have a flashing system for hot pipes that could cause a fire if too close to lumber.
rcamacho
818
Bainbridge Island Wa
Under construction. I will get the tin on at least for the winter. Big enough for drum storage and any additional cans. Enough room for me to stand next to it for maintenance. All doors easy accessible. The walls will be removable 1x4 with a 2” gap between, plenty of ventilation run horizontally
Might be a tad close to the house for noise and fire risk?
Do you have enough room to service the back side of the generator?
Beschneid
39
13
Pepperell MA
That is my garage which is separate from the house, can’t hardly hear it in the house. There is almost 2’ on the back side to get around. Not concerned about to much heat. I do need to get a bigger extinguisher for that side of the garage. Thanks for the concern.
Farmitall
276
Eubank, KY
Just busting balls. :giggle: I usually only throw the tarp over it if snow is predicted.
Putting the generator under cover is always a good thing as long as it's far enough away from any other structure in case of a fire.
I don't even park my vehicles close enough to my house or garage for the same reason.
Evvy Fesler
772
LOL - I'm one of the few on the forum where it's impossible to bust mine!👧
