Securing your MTVR? anyone installing locks? ignition keys?
MTVR
747
Waco Texas
I don't know if I have a record of the part number, but I looked it up again. I'm finding Velvac part number 600169-1 and 600169-6.
Any brand of aluminum 4" non-vented female 8 thread per inch locking fuel cap will work. The numbers I gave above, may cross over to other brands if you do a little digging...
GTUnit
153
CA
Looks Like Sloan 431006 (SLN431006) cross references to Velvac 600169-6
Aluminum Locking Fuel Cap, Female, Non-Vented, 4" Nominal Size, 8 Threads Per Inch | Velvac
Options:
Locking, Non-Vented
Material: Aluminum
Nominal Size: 8"
Threads Per Inch: 8
Across Threads - Filler Neck (inches):4-7/16"
Across Threads - Cap (inches):4-3/8"
Note:For diesel applications only.
One of the least expensive sources found so far:
4" Fuel Cap, Aluminum, Locking - Triple "R" Truck Parts (triplertruckparts.com) $65
serpico760
1,738
San Diego, CA
The door handle with lock is available, just not cheap at over $100 each. Here is a link https://www.ebay.com/itm/Oshkosh-31...050096?hash=item41d76bf270:g:IRoAAOSwcj1aQ655
The striker plate is available too. https://mpparts.com/part/oshkosh-3192882-cab-door-striker-3192882
I am buying the air brake knob lock too. https://www.amazon.com/gp/product/B..._title_srh_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
I bought better door handles for my FMTV from Austinhardware.com. there's tons of door handles on there probably the same one that the MTVR uses is commercially available for less than half the price. They come with locks and keys also
19,762
Sure would be nice to figure out what the MTVR handles are in the commercial world...
chucky
18,965
TN .
Well give us a picture of em ! I have run slap the hell out of something to do so give me a mission ! Who mfg the cab it should be on something maybe in the door facing they usually dont get out of their comfort zone unless someone request a certain part they dont normally use!
serpico760
1,738
San Diego, CA
I've contacted the account manager of a commercial supplier of automotive door handles with photos of the handle to see if they can figure it out. If so they should be about half the price that the guy on eBay was selling them for. They helped me with handles for my M1083. I'll let you know if they reply with a match.
19,762
Well by golly...
Here are some pictures!
01 - MTVR Outside.jpg 02 - MTVR Outside Open.jpg 03 - MTVR Inside.jpg 04 - MTVR Outside Inside.jpg
Don't know that anybody needs the inside latch picture, but somebody may know more with how this thing is configured with those two pics. AND there is a place for a lock - if you knew what kind of lock you (we) would need.
serpico760
1,738
San Diego, CA
serpico760
1,738
San Diego, CA
If you search online for TriMark 030-1400 or 030-1450, they look extremely similar.
if you go to the product page there's the technical specifications with the cutout size and the linkage points etc. I'm pretty sure this one will work so long as it fits in the same hole it also mounts in an upright configuration like the MTVR handle.
On Amazon and eBay the same handle is also available in all black which of course then you can paint to whatever you like. And with keys. If you buy it from Austin hardware after confirming that it works they can send you a left and right set with matching keys.
19,762
Agreed that they look similar.
The link you sent was for a "two point" and the one on the truck is a "one point".
The link looks a lot like the LMTV handle.
Might be that I could spend the time to remove one and get more details.
Maybe a casting number or something similar...
serpico760
1,738
San Diego, CA
Yeah they often have more points than needed you use the ones you need and just leave blank or cut off the ones you don't.
