M1078 outer reduction
Xengineguy
764
USA Indiana
Guess what happens when someone puts the outer needle bearing washer on the wrong side of the needle bearing?
Makes a mess! At least I found where the metal shavings on the magnet came from. Looking for some parts,
posted in the wanted section. :(
serpico760
1,594
San Diego, CA
Man I've never reassembled something the wrong way and... Um ... Parts made a horrible miss and destroyed themselves...
Nope that's never!
Well except for maybe that one time when I had some bolts left over that I found later.....
Xengineguy
764
USA Indiana
Nope that's never!
This mess was caused by one of the past military mechanics, I can’t take credit for it. I was simply pulling an axle and a washer was
between the end of the axle and the outer hub. Pulled the hub and found the problem. The outer gear would probably be ok, (light pitting thru the hardened surface). And could cut a deeper groove for the snap ring on the axle. But I would rather get some parts.
Side note, the hubs were always cool and consistent with each other??? I think the damage was done some time ago.
