My humvee has blown 2 voltage regulators and im on the 3rd one already. It seems that each time they went bad after accidentally shorting one of the battery cable under the passenger seat and its getting expensive to keep buying them. I have installed a grounding harness and im thinking that I should install a bus fuse somewhere between the regulator and one of the 3 terminals (IGN, AC, +14). I would like some advise as to which terminal should be fused and what amperage fuse I should use.
Any help is appreciated and I thank you in advance
