loosegravel
Just a retired mechanic who's having fun!
- 504
- 892
- 93
- Enumclaw, Washington
Today I’ve been working on this MEP-831A 3kw unit. I bought it home a couple of weeks ago. Initially I found that the Yanmar engine was missing one of the rocker arms and it had a bent push rod. I was able to get those parts and I installed them today. It’s also missing the lever on the inside of the valve cover for the compression release. The red lever is there on the outside, but nothing to make contact with the exhaust rocker on the inside. I’m not concerned about that right now, I’ll get back to that later. But I’m not getting any fuel at all out of the fuel pump. It looks like it’s been messed with, but without a comparison I have no idea if it’s missing some internal par(s). I can see with it installed that it’s engaging with the fuel control rack. With the fuel pump out, I can see the cam follower going up and down when I crank the engine over. Just one .010” mounting shim. Any thoughts or ideas? Thanks, Jeff
