FMTV wiper bottom position.
serpico760
1,707
San Diego, CA
I noticed when my windshield wipers go up the driver side one doesn't go far enough towards the A pillar. I positioned the first two wipers a little bit higher and then tested it out. I noticed when they dock under momentary usage it's not the far down position that they dock in. When it stops its cycle and then continues again it dips down first before going back up. Is this normal? Wouldn't the lowest point supposed to be the docking point that it would stop at? Perhaps there's some leaver or something that I need to adjust inside?
Click the link for the video: FMTV wiper cycle
GeneralDisorder
5,190
Portland, OR
Yours have probably done what mine did and the lever at the motor has slipped on the splines. The motor is under the PDP and you can loosen the nut and move the lever on the splined taper drive on the motor to line up it's parking location with the wipers at their lowest point. Mine the nut was just slightly loose and my lever slipped on the splines and my wipers were parking straight up and down. Really easy fix though.
serpico760
1,707
San Diego, CA
Thanks for the info man I'm going to try that soon!
Third From Texas
6,498
Corpus Christi Texas
Yeah, one of these days....
