- 488
- 366
- 63
- California
Yes, thanks for bringing that table up, I have those spcs in the H1 manual, I presume those bolts are GR8.I will look and see if I can find the specs, on "regular" steel steel connections you can look up the fastener specification, thread size/count/grade.
This would be OK for the exhaust elbow.
IIRC it is an M8 bolt.
Very good guide for items that the specs are hard to find.
My elbow bolts were so tight or stuck that the C side of the wrench would open and slip before the bolt would move, that's how I rounded one somewhat, after which I used the closed ring side, with a wooden block pressed in to stop the wrench it from slipping out due to the wrench's ring angle and opened the screws using a breaker bar (large steel tube from the 4 ton floor jack inserted over the wrench).
