All of them, thats weird.
@superman may have an idea, but nothing I have seen shows the solenoids as a discrete component. There are at least two manifold block variants used on the LMTV that I have seen and they use different style pilot solenoid assemblies to manipulate a small amount of air to open and close the large volume core valves inside the PCU manifold. The coils themselvs may be a fairly standard 24v solenoid coil, you would just need to find one with the right bore length and diameter to fit over the mount tube…
