White smoke at idle and driving.
Mogman
10,218
Papalote, TX
I would do a cylinder rpm drop test as suggested earlier, If you had a cylinder issue it would narrow it down.
flyn2low737
22
Houston
If the unburnt fuel is bad enough, start it when cold….turn it off within a few seconds of starting, start pulling glow plugs till you find the wet one, there is your problem cylinder….done it may times
I will give that a shot. Do I need a specific glow plug tool for these? I have done plugs and injectors in my truck 7.3 Ford with just standard tools.
Mogman
10,218
Papalote, TX
If you have a dead cylinder the idle will not change when you loosen the injector line to that cylinder, no real need for a tach.
If you have a dead cylinder it will be pretty obvious and busting the injector lines is allot easier than pulling the glow plugs.
flyn2low737
22
Houston
Any chance a sticking/failed injector would cause smoke to come out the intake? I ask as the intake bolts were loose on that side and I had soot on the exterior of the intake runners and an exhaust ticking that disappeared when I tightened the intake bolts. Kinda worried I have an issue in the head.
Mogman
10,218
Papalote, TX
I am not sure what you were seeing, I would bust the lines loose one at a time and see if I had a dead cylinder, then I would do as RWH said and pull the glow plug on that cylinder and do a compression test.
Usually a bad injector will cause a knock, not always but most of the time.
If you do have raw fuel comming out of the exhaust it is likely a compression issue, if raw fuel is somehow being dumped into a cylinder with compression it will fire early and knock like hell.
Mogman
10,218
Papalote, TX
you can also remove the run solenoid wire and if you have a cylinder that has no compression you will hear it "skip" or speed up when it comes to compress that cylinder, will not help to figure out which one though.
flyn2low737
22
Houston
  • Like
Reactions: OBX
flyn2low737
22
Houston
Alright I found one cylinder that makes the idle worse when it’s tight. When I loosen that injector the cylinder idle drops slightly but the idle overalll is better. There is also a knock I am getting from it but not consistently when the injector is snugged up. The knock definitely subsided when it’s allowed to leak. Sooo sounds like I need an injector but I will verify tomorrow and do a quick start and pull the glow plug on that cylinder. Should I go ahead and do a compression check?
Mogman
10,218
Papalote, TX
I would be tempted to drop an injector in, unless you just have a diesel compression gauge with the correct adapter handy.
Hopefully it is an easy one to get to.
flyn2low737
22
Houston
Of course I don’t have that tool yet. Good excuse to get one.
Passenger side 2nd one from the front. Not the best spot. Any suggestions on a good source for the injectors. All the ones I find are for a turbo.
Mogman
10,218
Papalote, TX
You can open a can of worms pulling a glowplug, most say if its bad it needs to be pulled anyway, just be ready to purchase a quality extractor if only half of the glowplug comes out.
You might look at the usual places for an injector, mac motors, Seco, hummer parts guy, AMG does not seem to have any listed, you can also put a want out in the SS classified but you have to be a supporting member (everyone should it's a great forum!)
You need to get the numbers off of your pump to match what injector you want
Mogman
10,218
Papalote, TX
Or you can pop it out and have your local diesel injection shop look at it if you have one.
Seco lists the same injector for both the 6.2 and 6.5L NA engine
blutow
501
Austin, TX
If the motor runs better without fuel to that cylinder, it seems like it might be a problem with the cylinder rather than the injector. Did the smoking stop when you cracked the line? I’d consider swapping injectors with another cylinder and repeat the test. If the problem moves to the other cylinder, good chance it’s the injector. It it stays with the original cylinder, it’s something unrelated to the injector.
