.Theres many designs on youtube if you have a hitch that keeps the back of the truck clean till you need a crane/lift to do what ever then put it away !
with a longer arm that folds in middle or so...... you could prior to lower... swing it all way out to the side... pull pins.. allowing hinge to knock the arm 90 degree that tires hangs from.... resulting in tire now sitting about exacly over the rear axle. As you finish lowering it down..... your right next to your axle end. Mayyyyyybe with engineering wizardry you could even; as you lower it... guide it right onto the lug bolts.I am contemplating something like this…..
Spare wheel holder and lift for our expedition truck
Fabricated by Johan from Whitewood Campers, our new hydraulic spare wheel holder and lift. It holds 2 spare wheels, size 365/80R20 or 14.5R20 in old money, t...youtube.com
Also like this one.
Coach,with a longer arm that folds in middle or so...... you could prior to lower... swing it all way out to the side... pull pins.. allowing hinge to knock the arm 90 degree that tires hangs from.... resulting in tire now sitting about exacly over the rear axle. As you finish lowering it down..... your right next to your axle end. Mayyyyyybe with engineering wizardry you could even; as you lower it... guide it right onto the lug bolts.
granted.... if it is a front tire...... your back to a shiat job of rolling the tire from spot it was lowered... to the front for installing and pray you dont drop it.... (cause if your a skinny ass person like me... now you cant stand it back up and your fawked ... untill you put yourself together a temporary lever to tilt it up a bit... then give yourself a hernia standing it up the rest of the way.... only to drop it again on the next clump of grass/bush you could not get it to roll over)
So with that in mind...... the rack and lowering device...... is only small part of the system. Also make sure you have a sound way to MOVE THE TIRE to where it will be mounted and a way to move the flat one (that may not roll) back to the rack. Also a way to pick up the tire if you drop it. (YOU WILL DROP IT by demand of Murphy's Laws) ..... so either carry a platoon with you- or create some wheeled craddle thing that prevents it falling over as you move it, or roof to winches to pull it back up orr?
Did you end up finding something like these or are you fabricating your own? I’m still searching for an option that works with a departure angle habitat.I am contemplating something like this…..
Also like this one.
For our tires, you have to fabricate something. I doubt you will ever find off the shelf stuff.Did you end up finding something like these or are you fabricating your own? I’m still searching for an option that works with a departure angle habitat.
