And for our regularly scheduled programming of "It's always something", I've recently started seeing bizarre shift behavior:
Here is a quick video of what's going on:
About 2 weeks ago, I was driving the truck around 45MPH, it was in 4th gear with low RPMs. As I'm driving, the RPM suddenly came up a bit as if it had downshifted, even though I hadn't changed pedal input or terrain incline. Figured it was definitely out of the ordinary considering I haven't seen it ever do that. I stopped, shifted into 1st, and began some troubleshooting. Here are my observations:
- Transmission will act normal for a while after startup and driving around
- Once I get over 40MPH, it'll sometimes kick up the RPM and feel like it downshifted, although I don't know if that's the case
- After it goes "bizarre", the truck will then upshift from any position on the shift lever, including 1st
- Upshifts from any position other than Circle D Overdrive are rough
- Upshifts from Circle D Overdrive are normal and smooth
- No amount of shifting corrects this
- Stopping the truck, putting it into park, shutting it off, and then starting it back up corrects the issue for the rest of the trip usually
Another set of observations that could possibly related:
- I start the truck one day after it had been running for a bit, wait light never comes on, whereas it should normally flash briefly if it's already hot
- I start driving around, I notice that my battery isn't charging, my temp gauge reads low due to the reduced voltage, and the cab heater and AC switches don't work
- Clearly some set of systems didn't turn on properly, shutting off and starting back up again corrected the issue
- Electrical gremlins are at it again
These are my observations, I haven't done any deep troubleshooting yet, going to run through some troubleshooting flowcharts soon and see what I can find. Will report back on anything else I see.
