M35A2 Master Cylinder Bleeding
wiggall
151
Lenore, Id.
How do you bleed the Master Cylinder on a M35A2? I have checked the manuals, and I do not have access to a power bleeder.
glcaines
2,712
Hiawassee, Georgia
Bleed the air pack first and then each wheel, starting at the wheel farthest from the MC. Takes two people to do it manually and some time is involved. Be careful, it is very easy to empty the MC and get air back in the system and then you have to start over. Make sure you are using the correct type of fluid. The default is DOT 5, which is silicone. It is absolutely incompatible with DOT 3 or DOT4. Also, don't use DOT5A, which is different from DOT5.
davidb56
1,238
Bonners Ferry Idaho
yes. Good to point that out, autozone and others try to sell the DOT5A as DOT 5.
